Polarity Independent Power Design
Discussion in 'General Electronics Chat' started by cackharot, Feb 10, 2011.
  1. cackharot
    Feb 2, 2011
    13
    I need to design a power supply circuit with the following spec
    1) AC input 120-240V AC 50/60Hz or +-48V DC
    2) DC output 24V at 1.5A
    I know the normal part that 240VAC to 24VDC using transformer, rectifier, filter and Linear regulator using LM317.
    Buy I need help regarding how to convert +-48DC to 24V DC.
    Looking forward to ur help!
    Thanks.
  2. tom66
    May 9, 2009
    2,613
    214
    Well, you could use the same bridge rectifier, and put the resulting ~46VDC into a DC-DC converter.
  3. cackharot
    Feb 2, 2011
    13
    Sorry, I dont actually get u. Could u post a rough circuit.
  4. tom66
    May 9, 2009
    2,613
    214
    I don't have a circuit. But you can have a look at suppliers like National Semiconductor. Their "Webench" will give you a circuit. Input DC volts 25V to 50V (give some error on both ends), output voltage 24V at 1500mA.
