Poisson probability
Discussion in 'Math' started by boks, Feb 23, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    The number of ships X that arrives at a port during a day has proven to be given by a Poisson distribution with E(X) = 2. Which number of ships has largest probability of arriving on a certain day?
    Attempt.
    <br />
p(x;2) = \frac{e^{-2} \cdot 2^x}{x!}<br />
    The formula yields
    p(0;2) = 0.135
    p(1;2) = 0.270
    p(2;2) = 0.270
    p(3;2) = 0.180
    and then values of p approaching zero. The numbers of ships most likely to arrive are 1 or 2.
    The port can handle at most 3 ships a day. Redundant ships are sent to another port.
    What's the expected number of ships that are handled each day?
    Expected number= 1*0.27 + 2*0.27 + 3* 0.18 = 1.35 (Correct: 1.782)
    Which capacity is necassary to be able to handle all incoming ships on a day with 90% certainty?
    No idea...
  2. Mark44
    Nov 26, 2007
    626
    You have three questions here by my count. Here are some suggestions for answering them.
    1. "Which number of ships has largest probability of arriving on a certain day?"
    For what value of x (not limited to integer values) is p(x, 2) the largest? To do this, you would need to differentiate p(x, 2) set p'(x, 2) to zero, and solve for x. A complication is that p(x, 2) has a factorial in the denominator, but you can replace x! with Gamma(x + 1).
    2. "The port can handle at most 3 ships a day. Redundant ships are sent to another port. What's the expected number of ships that are handled each day?"
    This might be a naive approach, but isn't the expected number of ships E(x)? For a Poisson distribution, the mean and variance = lambda = E(x), which you give as 2.
    3. "Which capacity is necassary to be able to handle all incoming ships on a day with 90% certainty?"
    I think what you want here is the value of x for which p(x, 2) <= .9, which you should be able to find from a table of values for Poisson distributions. The idea is that you want to find the value of x for which 90% of the area under the curve lies to the left of x, and 10% of the area lies to the right.
    Hope these suggestions are helpful.
    Mark
