Poisson distribution
Discussion in 'Math' started by boks, Mar 25, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    In a Poisson process with intensity λ, let X1 be the time untill the first event and let X2 be the time between the first and the second event. Let Y be the time untill the second event, that is, Y = X1 + X2. Find the density function f(y).
    Attempt:
    Probability that no events occur in time y:
    <br />
p(0; \lambda X1) = e^{- \lambda t}<br />
    I don't know if this will be helpful at all...
  2. AlexK
    May 23, 2007
    34
    To find the PDF of Y, you must first find the probability P{Y<t} or P{Y>t}.
    I think you are in the right direction you just have to translate the probability of times to the probability of events.
    P{Y>t}=P{"No events between times x1 and t"}=P{"Only one event until time t"}=.....
    Hope this helps,
    Alex
