point to point communication
Discussion in 'General Electronics Chat' started by mmuj, Apr 22, 2016.
  1. mmuj
    Dec 15, 2009
    11
    Hi
    I am working on point to point communication system over dedicated coaxial cable.
    Required Data rate = 100kbps
    cable length = 5km
    I am looking for suggestion/design ideas
    In one of my previous projects I used wire line modem (CMX866) successfully over similar distance but baud rate was 2400.
    Can I use two DSL modem ICs for such communication? are DSL chipset ICs available for Digikey/Farnell? i couldn't find any from product profile of TI, Analog or ST etc.
    I know Broadcomm is a key player in this market but they don't have good reputation for supporting small volume/ niche market customers.
    Any other ideas?
    mmuj
  2. SLK001
    Nov 29, 2011
    852
    243
    Three miles of cable? Really?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Can you specify the coaxial cable and the carrier frequency?
    If so I would suggest 75 Ohm CATV coax and 300-800 MHz.
    You might need to use either repeaters or substantial power levels.
    Industrial grade RF modems should work for you.
  4. mmuj
    Dec 15, 2009
    11
    Required distance is over 3 miles on an existing coaxial like cable, and to though spanner in the work, with the temperature range of at
    least 150C.
    Thnks Papabravo, can you suggest any suitable chip for FR modem type communication?
    I also thought about using Power line solution from TI using AFE031.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I wasn't thinking of chips, but rather complete modules. Doing an RF modem is not a single chip affair, there is more to it, not to mention the cost of the test equipment you'll need.
  6. Sensacell
    Jun 19, 2012
    1,184
    277
    The 150 Degrees C. spec is a bitch.
    How about sending the signal as base-band serial data?
    Attenuation in coax is proportional to frequency, direct signaling minimizes the loss.
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    Not if you build the entire system out of high power MOSFETS and dual Shottkey rectifiers. But other than that, I gotta ask - what task is 3 miles long and 300 F? Distributed sensors around the rim of an active volcano? Inquiring minds...
    ak
  8. Picbuster
    Member
    Dec 2, 2013
    391
    53
    it's commercial available look at https://www.scribd.com/doc/114590501/DSL-leased-line-modem-Realgain-4
  9. Tonyr1084
    Sep 24, 2015
    637
    112
    Is Fiber Optics an option?
  10. mmuj
    Dec 15, 2009
    11
    You are not that far off :)
    it is a last option
  11. SLK001
    Nov 29, 2011
    852
    243
    Is this for some down-hole logging tool?
