Point on wave device
Discussion in 'The Projects Forum' started by topopo, Sep 24, 2009.
  1. topopo
    Sep 23, 2009
    Hello everyone,
    I am trying to find a device that can turn ON an inductive load at a specific angle (0; 45; 90 deg etc) on the voltage wave.
    Could anyone please suggest how I should start this project?
    Better yet, if anyone could point me to the right direction where I can buy a product like this off the shelf that would be the ideal.
    Thanks all,
    Peter
  2. JDT
    Feb 12, 2009
    658
    85
    A phase-controlled triac or SCR will do this.
    What is your application?
  3. topopo
    Sep 23, 2009
    Hello JDT,
    Thanks for your reply. I will do some research on the phase-controlled triac.
    My application is to trigger (latch on) a contactor at a specific angle on the voltage waveform for a set period of time, i.e. 1-cycle (20ms) or 2-cycle (40ms). I am also wondering if such device can be bought off the shelf?
    I hope that makes sense.
    Thanks again everyone.
    Peter
    Edit:
    Added a waveform of the point on wave that I am describing.
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What is the device it's going to trigger?
  5. topopo
    Sep 23, 2009
    Hello blueroomelectronics,
    The device I am going to trigger is a contactor, i.e latching the contactor ON. The contactor is basically switching a high current load (100-500A) at 45° of the voltage waveform for 20 - 40ms.
    Please refer to the diagram I have attached in my previous post.
    Thanks,
    Pete
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Do you have a datasheet on the contactor?
  7. topopo
    Sep 23, 2009
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    Have you considered the pull-in time of the contactor? They're not that fast you know. I couldn't find that spec in your data sheet but I wouldn't be surprised that > 5 cycles @ 60Hz would pass before the contacts closed, and this doesn't include contact bounce!
