POF photodiode help
Discussion in 'General Electronics Chat' started by tronicsguy, Oct 6, 2005.
  1. tronicsguy
    Oct 6, 2005
    9
    I am designing a voltage to light and light to voltage transducer.
    They have to be linear.
    For the V to Light, I used an op amp. Similarly for the L to V, I used an op amp.
    At the light to voltage end, I am using the IFD 91 photodiode. I am not getting a linear response at this end. something like an S curve. Its not linear at the lower end and the higher end.
    I don't have a light meter. So I am measuring the voltage at the output of the op amp.
    Are photodiodes not linear?
    Any ideas/suggestions to correct this.
    TIA.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    First of all, get the mfr's specs on the photodiode. That will tell you about the non-linearity issue. That document will also suggest a typical circuit for a maximally linear output.
  3. tronicsguy
    Oct 6, 2005
    9
    I already did contact the manufacturers. No reply yet.
    The data sheet does not have a typical ckt.
  4. tronicsguy
    Oct 6, 2005
    9
    I got the datasheet, but it was of no use. No typical ckt ideas.
    The response of the photodiode is initially (first 40% of the full scale). I just decided to use the output after it crosses this scale.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I seem to remember that photodiode circuits had lots of resistance. I think the PD is happy running in low microamp regions. A stable FET input op amp will be the thing to use.
