PoE Supply Fault
Discussion in 'General Electronics Chat' started by Muhammad Farhan Rafique, Apr 15, 2016.
  1. Muhammad Farhan Rafique
    Apr 15, 2016
    i have a PoE module "AG 9400".
    all installed parts are ok but module is not providing 12 Volts.
    it seem's that the module is not providing Class 0 signature to PoE switch.
    i need help.
  2. Alec_t
    Sep 17, 2013
    5,956
    1,132
    Welcome to AAC!
    How have you determined that?
  3. Muhammad Farhan Rafique
    Apr 15, 2016
    i have one good module. i exchanged all parts from good module to bad module including I,C, FETs, Bridg Diodes, Chopper etc. (except micro resistors and ceramic capacitors). good module still working and bad module isn't.
    when i connect good module steady power is provided from switch and when i connect bad module there is only pulses and spikes of high voltage.
    what i read about this module is:
    PoE switch first identify that whether the connected device need power on switch port or not by checking class 0 signature.
    i don't know which component provide class 0 signature to switch.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
