pnp transistor which is base+collector+emetter
Discussion in 'General Electronics Chat' started by newone, Jan 15, 2006.
  1. newone
    Dec 23, 2005
    14
    there is 3 legs
    left+center+right
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The assignment of pins is up to the manufacturer, although TO-92 packages are pretty standard. This means you have to have the device number and then look it up.
  3. mozikluv
    Jan 22, 2004
    1,437
    hi,
    you can check my post on this topic Posted on: Nov 29 2005, 09:31 PM ID on PNP
    that might help
    moz
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Need to know the transistor type (code written on the transistor) then cross reference that with a datasheet, of database.
    If you post this number, Im sure someone can check for u.
