PNP transistor (Sziklai) question
Discussion in 'Homework Help' started by TsAmE, Oct 4, 2010.
  1. TsAmE
    Apr 19, 2010
    72
    What is the minimum input current I for which the transistor will begin to turn on?
    I dont understand why the answer is the same as the current through the 47k resistor (I = 1.489µA). Wouldnt the answer be different, since the current at the junction spilts? (some goes to the base and rest through the resistor?)
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    For the second transistor to begin to turn on the first transistor must start conducting. The spec wouldn't change since the second transistor is entirely dependent on the first.
