As you can see from prior posts, and you already know, this is an unusual circuit to design. I thought about it for a few minutes. Consider this. Suppose you have your existing 150 VDC supply with some AC signal on top of it. Connect that through two resistors to a negative supply, like -150 VDC. Now you have a resistor divider. You want the upper resistor to drop a nominal 174 VDC, and the lower resistor to drop 126 VDC, to get a nominal -24 VDC. It's just a resistor divider. Naturally, you'll use large resistor values which you can calculate. Your AC signal will be reduced by the ratio of the resistors, of course, but perhaps you can make up the loss with the next stage of amplification. This is a very brute force approach, and it wastes a lot of energy, but it's a place to start. How does that strike you?Hello, I am trying to get a pnp transistor to carry an ac signal linearly from a high positive voltage source to a low negative voltage output.
I tried this
but this is what I got out of it
The pnp transistor was specifically designed for audio http://www.farnell.com/datasheets/866302.pdf
What could be causing the distortion in the 0-6k frequency range?
