PNP BJT simulation problem
Discussion in 'General Electronics Chat' started by xxxyyyba, May 20, 2013.
  1. xxxyyyba
    Aug 7, 2012
    249
    Hi!
    Here is my circuit:
    Code ( (Unknown Language)):
    1. http://oi44.tinypic.com/2zszn7a.jpg
    I guessed that pnp works in direct active mode. I got that Ib=0.01mA, Ic=0.95mA, Ie=0.96mA, Vbc=4.28V>0 so my guess is correct. I simulated circuit in Multisim but I got different results. What's wrong? Did I make mistake somewhere in calculations?
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
    Your BJT in the multisime is upside down.
  3. crutschow
    Mar 14, 2008
    13,526
    3,393
    The last two images are too small to see the detail. Insert them as .gif or other graphics format directly into you post, using the insert Attachments (paper clip) icon in the Go Advanced window. JPEG is for pictures and makes fuzzy drawing renditions.
  4. xxxyyyba
    Aug 7, 2012
    249
    @crutschow
    I hope it's ok now.
    @Jony130
      File size:
      8.8 KB
      37
  5. Jony130
    Feb 17, 2009
    3,995
    1,117
    Now everything looks good. You Sim BJT has slightly larger current gain and Vbe also will be different. And this is why sim show slightly different result than your hand calculations.
  6. xxxyyyba
    Aug 7, 2012
    249
    Thanks a lot!
