PN918 RF Transistors
Discussion in 'General Electronics Chat' started by radiohead, Jul 1, 2011.
  1. radiohead
    Thread Starter Active Member
    May 28, 2009
    474
    31
    I was recently given about one hundred PN918 RF transistors. I searched for schematics for RF amplifiers or other circuits that use this transistor without luck. All that comes up are datasheets from various manufacturers. No wonder I got them for free.
    Can anyone point me in a direction to where I might be able to put these things to use? Small projects, simple RF amps, etcetera..
    Thanks.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Gee, why not build the test circuit in that PDF for starters? See if you can get them to oscillate at 500MHz.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  4. radiohead
    May 28, 2009
    474
    31
    Wookie, that was the first thing I did. I was just inquiring if that is the only circuit out there that uses that transistor.
    Bertus, thank you. This points me in the right direction.
    Thanks to everyone for the helpful input.
