Pn2222a
Discussion in 'General Electronics Chat' started by rvm.karthi, Feb 10, 2010.
  1. rvm.karthi
    Dec 29, 2009
    13
    hI I AM MAKING A CIRCUR WHICH HAS PN2222A TRANSISTOR AS SWITCH... MY DOUBT IS HI=OW MUCH VOLTAGE REQUIR IT TO TURN ON....? ALSO FOR ALL OTHER GENERAL TRANSISTORS....?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To be literal, about 700 mv will forward bias the transistor into conduction.
    You probably want to know the level of base current to operate the transistor as a saturated switch. Our Ebook may give you some guidance - http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. rvm.karthi
    Dec 29, 2009
    13
    Thankz u all.... Will be back with someother ....
  5. rvm.karthi
    Dec 29, 2009
    13
    Hi
    i am here with a new prob...i would like to turn on this transistor(2222a) using the o/p from IR phototransistor...i use 5vdc with 330 ohm reistor for IR phototransistor...also i like to turn on the 12vdc relay when the transistor(2222a) turned on....pl help me...
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Can you post a schematic of the circuit that you have upto now?
    In that way we can have a look what needs to be changed.
    Greetings,
    Bertus
