PMW control by temperature
Discussion in 'General Electronics Chat' started by mdcarvalho, Sep 14, 2008.
  1. mdcarvalho
    Jun 13, 2008
    Hi new here if I don't know how to procedure I do apolidise
    I would like to know if anybody could help me how could I control the duty cycle of a pmw modulator (555 Ic for instance) by temperature with a ntc
    Thermistor
    thank you
    Marcus
    [​IMG] [​IMG]
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    There are a number of example circuits on the web such as this one.
    I bit of googling can uncover quite a few 555 based PWM controllers with temperature control.
    Of course, some alterations will be needed to get the functionality consistent with your application.
    hgmjr
  3. mdcarvalho
    Jun 13, 2008
    yes I have seen those circuits on the net as a matter of fact the one I am using is similar to the one you point me to I was think of a circuit that would uses two transistor (NPN & PNP) instead of those two diodes and the 100 kΩ pot please see atachment . Than control the base of the two transistor with the thermistor that way I would not change the frequency. only the duty cycle
    but I don't have the enough knoledge to design the circuit
    Thank you for your interest I really appreciate
    Marcus
