PMT Noise
Discussion in 'The Projects Forum' started by Ravaner, Jan 31, 2012.
  1. Ravaner
    Apr 7, 2008
    12
    Hello. I use a PMT with a load of 50R directly connected to scope. In complete obscurity (0 mV) or with moderate light excitation output signal (60 mV) doesn't show any significant noise. But ... with very low lighting, close to complete darkness, a very important noise appears (amplitude 40 mV) Can someone explain this situation ?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    I have an ABC and my neighbour has an XYZ.
    You use a PMT.
    You don't know what I am talking about and I don't know what you are talking about.
    Why talk in Letters?? Why not name things??
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  4. joeyd999
    Jun 6, 2011
    2,756
    2,920
    Probably shot noise. PMTs count individual photons. Photons come at random intervals, causing 'white' noise. You can expect a 'crest factor' of about 6 (p-p noise is about 6x RMS noise). The S/N is proportional to the square root of the number of photons vs. time. No light, no noise. Little bit of light, lots of noise. Increase the light, and the noise drops.
    If shot noise is your problem, the only solution is to integrate your signal over a period of time, thus 'counting' more photons for each measurement.
  5. Ravaner
    Apr 7, 2008
    12
    Thanks for reply. Seems to be the right answer. As I have to digitize this signal at a frequency of about 1 MHz I don't know how to "clean" this shot noise.
  6. joeyd999
    Jun 6, 2011
    2,756
    2,920
    You cannot clean it. It is a physical phenomena that simply exists. There are three ways around it: 1) more light, 2) filter continuously (will affect your rise time, 3) integrate the signal for a long(er) period of time.
  7. DickCappels
    Aug 21, 2008
    2,758
    667
    Make sure your electrode supplies are clean -that's often a source of noise. Also, the tube may be reacting to the occasional nuclear particle, which can be shielded (You DID electrically shield the tube, didn't you?). Also, many tubes only put out microamps; if you are getting milliamps, you might be damaging the tube -check the datasheet if you can. Sorry, its been a long time since I used one.
  8. joeyd999
    Jun 6, 2011
    2,756
    2,920
    They are also susceptible to magnetic fields as well. They are sometimes shielded with mu-metal.
  9. Ravaner
    Apr 7, 2008
    12
    Thanks for all your replies. I put a 56R load and voltage indicates now few µA anode current. As the PMT has a lateral window, seems almost impossible to place a µ metal shield (bending, cutting ... will damage magnetic properties). But I will try to insert at least an electrical Faraday shield. PS : all that is placed in a very confined volume under high vacuum
