I am having trouble understanding what is called a PMOS pull-up network
vin is ate the gate
the source is at the top connected to power
vd is output, vout
and a resistor goes from drain to ground below the vout
When you turn it "off" you put in vg>vth or "high"
Doesn't it not get pulled up? It goes to 0 because of the conenction to ground.
I thought pull ups and down refer to the time when no current is flowing. So w/ high gate voltage it is "off" and it is not being pulled up
vin is ate the gate
vd is output, vout
