PMOS power supply cutoff switch
Discussion in 'The Projects Forum' started by rakeshm55, Mar 18, 2011.
  1. rakeshm55
    Oct 19, 2010
    68
    I wanted a highside pmos switch to cutoff 11V Battery power. Initially I placed a PMOS switch (in PSPICE) with control circuitry. For all the time the switch passes the voltage from drain to source whatever may be the gate voltage. Then I came across 2 PMOS switches in series with drain connected to others (refer to the image attached, Q1 and Q2 connected in the same format).
    Now when I simulate I get the required result.
    What is this configuration?I am still not clear about how it functions??
    I have seen the same configuration used in Battery protection circuits.
    pls Help
