PMOS pass transistors
Discussion in 'General Electronics Chat' started by Engineer-it-all, Jan 22, 2010.
  1. Engineer-it-all
    Sep 17, 2008
    5
    Hi Peeps,
    i have a question about Pass transistors.
    assume the MOSFETs are allways biased so they are conducting.
    input on drain, output from source and bulk is tied to source.
    an NMOS can pass 0 well. ok
    an NMOS can Pass (1 - Vth). ok
    a Pmos can pass 1 well. ok
    BUT
    the PMOS trying to pass a 0... my notes say the output is Vth, i can see why it should be this ( if Vgs = 0, Vds = 0 the channel is high resistance and only at (Vgs = 0 - Vth) does low resistance in the channel form)
    but as far as i can tell, this mosfet is generating voltages that come from nowhere. could anyone explain the 'magic Vth on the output of a conducting PMOS pass transistor with a 0 on the input'.
    Thanks.
    p.s also a completely unrelated observation. why is it ok to say
    "an NMOS" but is not ok to say "an PMOS"?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you post schematic examples of the circuits that you have questions about? That will make it much easier on people who would like to help you.
    Use the "Go Advanced" button below the reply text box, then "Manage Attachments" to upload images from your computer. .png format files are preferred; they are not "lossy" like .jpg images, but are very compact for line drawings
  3. kdillinger
    Jul 26, 2009
    141
    The voltages are coming from the circuit. There are no voltages if it is just lying there on the table. Am I reading your question correctly?
    The rule of thumb is 'an' is used when it precedes a word that begins with a vowel or the sound of a vowel. With nMOS, 'n' is a consonant but 'n' is pronounced as 'en'.
    For pMOS the 'p' is a consonant and the pronunciation also sounds like a consonant.
    "An hour"
    "A minute"
  4. Engineer-it-all
    Sep 17, 2008
    5
    sorry about the poor description, hopefully this pic will help.
    is this what you would expect from the 2 scenarios?
    A has the Vth on the Output as the gate is not lower than the signal being passed.
    B fully conducts the zero as gate is below this voltage by the appropriate amout.
    if this is correct, then in A, it appear's like the voltage is generated by the MOS itself.
    thanks again
  5. Ron H
    Apr 14, 2005
    7,050
    657
    You can't have a voltage on the source unless there is an external supply to provide it, like this:
  6. Engineer-it-all
    Sep 17, 2008
    5
    Safe, cheers for the help.
