Pm full-Need mod or adm's help
Discussion in 'Feedback and Suggestions' started by loosewire, Jan 19, 2011.
  1. loosewire
    Thread Starter AAC Fanatic!
    Apr 25, 2008
    1,584
    435
    I receive request to make room in my pm,so when I pm'ed
    I deleted a few messages. Now the few deleted spaces has
    disappeared. Bottom line question I want to the remaining pm's
    saved please give the help I need,look at this.I don't want press
    (empty pm) and lose all my messages. Please help me
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Have you tried again? Seems to me in the middle of a major transition such as a server move they are trying very hard not loose files, which could easily explain it.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    At the bottom of the PM page, you will see a box with something like, "move to folder..." Just export to a text file and send to Wikileaks.
    John
  4. loosewire
    Apr 25, 2008
    1,584
    435
    I pressed the empty folder button,I got a warning that said ,are you sure you want
    to delete all your pm's. I like the humor, how about some walk thru help.
    Like do this ,you will see this.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    It's a dropdown menu. Click on download as text.
    John
  6. t06afre
    May 11, 2009
    5,939
    1,222
    But remember Loosewire. By downloading your PMs. You may trigger some alarms in one of NSA computers. And then they will start to keep an eye on you. You may see strange vans in your vicinity. Men in black with sunglasses even if it is no sun. And perhaps hear strange clicking sounds in your phone. It is perhaps best to keep it on the AAC server:rolleyes:
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I save all my PMs as text. You never know when I need to dig up dir... and address on someone.
  8. nerdegutta
    Dec 15, 2009
    2,565
    806
    How is the full PM-box working out for you, Loosewire?
  9. loosewire
    Apr 25, 2008
    1,584
    435
    T06, One of my favorites when I mess up,(Dave Is that you backing into the drive way)
    Thanks Nerdegutte,I slide down to several options,I,m
    not sure which one,If I press text only. I hope John post
    some more steps.I need step by step,I don't want to lose
    100 messages.Need help,will text only hold 50 only don't know.
    I need to save 100 messages,need help.The picture thing
    works better for me. Breaking News,when I learn how to
    saftly post pictures,I have 2 picked out. Got to save the pm's.
    John I looked at your picture again, down load to text will
    that hold a 100 need to know before I press that picture.
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    You can select the messages with the tick-boxes behind every message.
    Then go to the pull-box and select download as text.
    See also the picture of jpanhalt in post #5.
    Afther you saved the messages you can select delete, and the selected messages will be deleted.
    This needs to be done for both inbox and outbox.
    Bertus
  11. loosewire
    Apr 25, 2008
    1,584
    435
    I am going to need more of johns pictures,I want to be really
    save about this,It means alot.
  12. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    From the FAQ:
    Bertus
  13. loosewire
    Apr 25, 2008
    1,584
    435
    Thanks,while I read all this.
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    When you go to the PM-box, you can select the files you want to download:
    Then you select the "download as TEXT" in the dropdown box and press go:
    Then a dialog box appears then select download file:
    I always add -inbox for the inbox file and -outbox for the outbox file.
    Then select "delete" in the dropdown box and press go:
    (be sure the text file is downloaded correctly).
    The same can be done for the outbox.
    Bertus
    PS I use the dutch version of firefox.
  15. Georacer
    Nov 25, 2009
    5,151
    1,266
    Wow! Talk about Moderator dedication...
