plz help
Discussion in 'Homework Help' started by giorgosxristou, Jan 11, 2006.
  1. 0 vote(s)
    0.0%
  1. giorgosxristou
    Jan 11, 2006
    hi to every one i have a problem with this homework is my last project for my university and i must give it until the next week and the problem is very big!!thank's a lot!!!
    George, study group 188
    1. With the aid of a synchronous sequential circuit implement a finite state machine with inputs a, b and output z according to the following transition and output tables. Employ an appropriate method of minimization and coding internal states. Verify the correctness of the designed circuit by marking the logic values in the schematic diagram of the circuit. Verify in this way two total states of the resulting automaton: one stable (the next state is equal to the present state) and the other unstable (the next state differs from the present state). Print the circuit scheme twice, once for each of the states mentioned above. Mark all wires with logic values (0,1,x). Indicate, which total state is represented by the scheme.
    \ba| transition table
    Qi\ | 00 01 10
    Q0| Q14 Q9 Q11
    Q1| Q6 Q9 Q13
    Q2| Q14 Q14 Q11
    Q3| Q4 Q0 Q11
    Q4| Q12 Q0 Q13
    Q5| Q3 Q3 Q5
    Q6| Q9 Q0 Q6
    Q7| Q4 Q12 Q5
    Q8| Q7 Q1 Q8
    Q9| Q3 Q3 Q7
    Q10| Q5 Q0 Q8
    Q11| Q8 Q8 Q13
    Q12| Q4 Q1 Q2
    Q13| Q10 Q8 Q2
    Q14| Q7 Q1 Q14
    output table
    00 01 10
    0 1 1
    0 1 1
    1 0 1
    0 0 1
    0 0 1
    1 0 1
    0 0 0
    1 0 1
    0 0 0
    1 0 1
    0 0 0
    1 0 1
    0 0 1
    1 0 1
    0 0 0
    Use D(FDC) flip-flops.
    1. Use gates NAND and NOR only.
    2. External input signals are available in direct form only.
    3. Assume that component delays (latencies) are equal to delays (latencies) shown in the home page of project.
    2. Derive the maximum applicable clock frequency under following assumptions: the input state can change in the interval < T , T + 3ns >, where T is the time when falling edge of the clock signal appears. Correct output state should last for at least 3 ns.
    The written report has to consist of:
    1. this project specification,
    2. the coding of internal states,
    3. coded transition and output tables,
    4. karnaugh maps for excitation signals of flip-flops and for external output signals,
    5. boolean expressions in minimal SOP forms for the above signals,
    6. the scheme of the designed circuit,
    7. computation of the maximum applicable clock frequency.
  2. MEGA_AMPERE
    Member
    Jan 14, 2006
    18
    umm there's some thing wrong in this
    i can do it BUT
    it will take a week to think a bout it and design it
    also I HAVE TO USE EX-NOR logic gate it's a must :rolleyes:
  3. peajay
    Dec 10, 2005
    67
    You can make that out of NAND gates somehow. I don't know how, but I know it can be done. I believe it takes four NANDs to make an XOR, and then you'd need a 5th to invert the output.
    I think (and someone check this because I'm too lazy at the moment) that with four NANDs numbered 1 through 4, with inputs A and B and output Q, that doing this will make an XOR:
    One input for the XOR goes to A1 and A2, the other goes to B1 and B3. Then Q1 goes to B2 and A3. Then Q2 goes to A4 and Q3 goes to B4, and Q4 is the output.
    That is if I remember correctly. It was something symmetrical like that. Then just toss a fifth NAND gate on the end to invert the output to get an XNOR.
