plz help me in THOMSON TG585 v7 modem
Discussion in 'Computing and Networks' started by Eng_Bandar, Jul 8, 2010.
  1. Eng_Bandar
    Thread Starter Active Member
    Feb 27, 2010
    50
    Hi all,
    I have this THOMSON TG585 v7 modem. How can I prevent certain user from access to my network?
    I don't prevent all only certain user.
  2. retched
    Dec 5, 2009
    5,201
    313
    Is he using your computer, or wirelessly using your modem?
    If he is using your modem/router wirelessly, You will have to DENY his IP address from using the router.
  3. Eng_Bandar
    Feb 27, 2010
    50
    yes he uses my modem wirelessly.
    but how deny his IP address? my router is THOMSON TG585 v7
  4. retched
    Dec 5, 2009
    5,201
    313
    The router should have software that allows and denies IP addresses.. You can also use a firewall that will not allow his IP to send packets to the router.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Did you enable the wep or wpa encryption for secure access?
    Take a look in the manual.
    Bertus
  6. tom66
    May 9, 2009
    2,613
    214
    You can also enable MAC address limiting, for devices which don't have WPA/WEP support. But beware this is fairly easy to spoof.
    Don't use WEP if you can. It's hideously outdated and insecure, you can crack it in 30 seconds or less by just observing data on the network.
  7. Eng_Bandar
    Feb 27, 2010
    50
    plz see these images ( in attachments )
    a,b,c,d ( names of images )
    I deleted green arrow in Allowed on WLAN and I pressed Apply button but I don't know why green arrow return. I don't return it.
    Is modem need to update ?
    Plz help
      File size:
      46.4 KB
      69
      File size:
      45.4 KB
      71
      File size:
      46.8 KB
      71
      File size:
      47.7 KB
      69
  8. Eng_Bandar
    Feb 27, 2010
    50
    Up up up up up up
