plz help in TL084 (Design Fn Genrator 3 stage ) on proteus
Discussion in 'The Projects Forum' started by mahmoudm36, May 9, 2015.
  1. mahmoudm36
    May 9, 2015
    hi guys i need some help in this design there no out put on oscliscope
    and this is the desgin for 5 stage
    i made 3 only and some thing is wrong but i don't know what
    what is the wrong in my desgin ??
  2. shteii01
    Feb 19, 2010
    3,501
    511
    Normal people start looking at one stage at a time. So... Does Stage 1 work?
  3. mahmoudm36
    May 9, 2015
    no :(
    And proteus does not tell me error in connection
  4. mahmoudm36
    May 9, 2015
    +ve 12 and - ve 12 on all op-amp is right or n't ?
  5. Reloadron
    Jan 15, 2015
    1,053
    275
    I don't understand those 12 volt power supplies and no they do not look correct. You have 12 volt batteries strung across the ICs and no power supply reference to ground.
    While I don't use Proteus I would try something like the above for +/- 12 Volts.
    Ron
  6. DickCappels
    Aug 21, 2008
    2,772
    669
    To elaborate on what Reloadron said, your circuit is trying to source and sink current through loads connected to ground but the power supply is not grounded.
