plz help identifying a problem in circuit
Discussion in 'The Projects Forum' started by arq, Jun 27, 2009.
  1. arq
    Nov 2, 2008
    16
    I have posted many mails previously regarding my ldr based sensor circuit.The purpose of circuit is to turn on or off the relay depending on the intensity of sunlight. Other side of relay is connected to 220v and bulb as a load.
    I have built this circuit using four methods.
    1. simple transistors.
    2. latching transistors.
    3. 741 comparator
    4. finaly with window comparator and sr latch.
    But all circuits have one common problem. At no load all circuits work well but at load on other side of relay flickering of load starts. May be due to AC some noise disturbs relay contacts.I am using electromagnetic relay. What about using solid state relay. I have never used one.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Can you post a drawing of the circuits used?
    Also can the LDR see the lamp?
    If the LDR can see the lamp the circuit will go oscillating.
    You can place the LDR in a tube and point it away from the lamp.
    Greetings,
    Bertus
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If the lamp is run off the mains, it will flicker at 50 or 60 Hz. So will the LDR output.
    The schematics would help.
  4. arq
    Nov 2, 2008
    16
    Four schematics are here
  5. arq
    Nov 2, 2008
    16
    Fourth schematic is here
  6. R!f@@
    Apr 2, 2009
    8,789
    771
    There could be two reasons for the relay flickering.
    1. The 12 Vcc cannot handle the relay current, the loading may cause the voltage drop thus switching off the transistor.
    2. Most likely is that your circuit is creating hysteresis. The switch which you use to turn on the relay is in the active region.
    The slow change in light causes the switching voltage to change slowly, if this happens the relay will flicker before turning on. What you need is a Schmidt trigger, or the window comparator window can be made wider.
    Rifaa
  7. arq
    Nov 2, 2008
    16
    i have added hysteresis in my circuit as well as i have increased window size, but problem does not seem to solve. Can anyone tell what are the possible reasons and solutions. and how to control LDR exactly
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    I think Beenthere's explanation is best. The light flickers at the mains frequency, which makes the LDR output flicker.
    What happens if you take the center schematic in post#4 and add a capacitor from the transistor base to ground? A rough guess is 10 to 100 uF, without knowing the base current or RV1. You could also add a resistor to the base (e.g., 1 K), which would effectively give you a low-pass filter.
    John
  9. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Almost certainly your relay coil is feeding back to the sensor input. I would put a resistor then cap to filter prior to the LDR.
