Plz Help!!!! Explain Me If Possible...
Discussion in 'Programmer's Corner' started by varunt, Apr 14, 2008.
  1. varunt
    Apr 14, 2008
    6
    HI.. CAN U EXPLAIN ME THE FOLLOWING PROGRAM...
    *#cpu 8051 Tiny
    * DDS MICRO-C 8031/51 Startup Code & Runtime library for TINY model
    * Copyright 1991-1999 Dave Dunfield
    * All rights reserved.
    ORG $0000 $0800 CODE Starts here (Normally in ROM)
    LJMP START
    ORG $0003
    LJMP SERVICE_EX0
    ORG $000B
    LJMP SERVICE_TIMER0_INTERRUPT
    * Fixed memory locations for alternate access to the R0-R7 register bank.
    * If you are NOT useing BANK 0, these equates must be adjusted.
    ?R0 EQU 0 Used for "POP" from stack
    ?R1 EQU ?R0+1 Used to load index indirectly
    ?R2 EQU ?R0+2 "" "" "" ""
    ?R3 EQU ?R0+3 Used by some runtime lib functions
    ?R4 EQU ?R0+4
    ?R5 EQU ?R0+5
    ?R6 EQU ?R0+6
    ?R7 EQU ?R0+7
    * Startup code entry point
    * If you are NOT using interrupts, you can reclaim 50 bytes
    * of code space by removing the following TWO lines.
    * AJMP *+$0032 Skip interrupt vectors
    * DS $0032-2 Reserve space for interrupt vectors
    START EQU *
    MOV SP,#?stk-1 Set up initial stack
    ORL TMOD,#%00000001 set timer 0 to be counter 16 bit
    SETB IE.7 $AF EA
    SETB IE.1 $A9 ET0 Enable timer 0 interrupt
    SETB TCON.4 start timer 0
    LCALL main Execute program
    SJMP * JUMP HERE
    * EXIT to MON51 by calling the 'timer1' interrupt vector ($001B).
    * This causes MON51 to think that a single-step operation has just
    * completed, and therefore it saves the user registers, and performs
    * a context switch back to the monitor.
    * When using 2K addressing (CC51: -Z option, ASM51: -A option) this LCALL
    * may fail "Out of range" because it gets translated to ACALL, and $001B
    * may not be in the same 2K block as your program. Since 2K devices cannot
    * support a debugger, change the ORG to $0000, and ...<continue below>...
    * If you are NOT using MON51 (or MONICA which works the same), you will
    * need to change this to whatever action you desire when main() returns.
    * Suggestions: 1:freeze (SJMP *) 2:Restart (SJMP *&$FF00)
    exit LCALL $001B Call Timer-1 interrupt
    SJMP exit Incase he go's again
    **************************** My code *********************************
    SERVICE_TIMER0_INTERRUPT EQU *
    PUSH ACC
    PUSH PSW
    MOV TH0,#$FF reload timer 0 for ms
    MOV TL0,#$00
    INC tick
    MOV A,tick
    CJNE A,#100,RIGHT
    MOV tick,#0
    RIGHT
    CLR C
    SUBB A,speedright
    JC ON_RIGHT
    CLR P1.0
    SJMP LEFT
    ON_RIGHT
    SETB P1.0
    LEFT
    MOV A,tick
    CLR C
    SUBB A,speedleft
    JC ON_LEFT
    CLR P1.1
    SJMP EXIT_I
    ON_LEFT
    SETB P1.1
    EXIT_I
    POP PSW
    POP ACC
    RETI
    SERVICE_EX0 EQU *
    INC cputick
    RETI
    $SE:1
    *#map1 Segment 1, initialized variables
    $SE:2
    *#map2 Segment 2, internal "register" variables
    ORG $0008 Internal ram ALWAYS starts here
    tick DS 1
    speedright DS 1
    speedleft DS 1
    cputick DS 1
  2. varunt
    Apr 14, 2008
    6
    Plz Help!!
    Hey,
    Can U Plz Tell Me The Use Of "$" And "#" Symbol While Programing In 89c2051.
    And Can U Let Me Know The Use Of Instructions "ds" And "org"
    While Reffering A Program, I M Getting Stuck At Following Instruction :
    Org $3000
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    # - the number sign - means that a literal constant follows
    $ - the dollar sign - indicates that the radix of the constant is 16. So what follows will be a hexadecimal constant.
    ds - this pseudo instruction reserves bytes of storage. How many is determined by the constant to the right of the ds operation.
    org - sets the value of the Program Counter.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Those are assembler directives, not program instructions. The assembler literature should explain all of that.
