Plz Help!! Emergency light circuit!
Discussion in 'The Projects Forum' started by aq_rules, Oct 29, 2009.
  1. aq_rules
    Oct 28, 2009
    168
    I need to design a circuit that consist 12V7AH rechargeable battery which is charged at 13-14 Dc v....
    this battery will be connected to a 12DCV Lamp (which runs without any transformer or circuit when i directly connect it to battery)
    Now i want such a circuit in which 13-14DCV from the MAINS are charging the battery and whenever MAIN breaks down the Lamp turns on it self....
    Plz help..diagrams would be more prefferable
    Thanks In advance...
  2. aq_rules
    Oct 28, 2009
    168
    Note:
    The battery should not be over charged...when it is full the circuit should stop charging it...
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Is this another homework assignment?
    You know that you really do need to research these kinds of things. There is a great deal of information out there.
  4. aq_rules
    Oct 28, 2009
    168
    No it isn't a h.w assignment. . .i want dis lamp to be placed in my room
  5. Bernard
    Aug 7, 2008
    4,240
    414
    Here is a control ckt. for battery-lamp minus charger which can be found elsewhere in AAC. With loss of AC , P ch MOSFET is turned on, turning on lamp R around 10k with MOSFET or darlington PNP transistor.
  6. aq_rules
    Oct 28, 2009
    168
    I want to place a relay in dis ciruit!. . .plz help
    by the way thanks buddy
  7. Bernard
    Aug 7, 2008
    4,240
    414
    Replace bulb with relay & diode.
