plz help !!!!circuits
Discussion in 'Homework Help' started by kitibwa, Apr 22, 2008.
  1. kitibwa
    Apr 10, 2008
    see attachment
    • qtn.txt
      File size:
      334 bytes
      10
  2. Caveman
    Apr 15, 2008
    471
    What's the deal? You have time for four exclamation marks, but not to type the details to your question? Type it out for cripes sake!
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Can you scan the question and upload it as an attachment?
    Dave
  4. mik3
    Feb 4, 2008
    4,846
    63
    It is just the graph of a cosine with t>0 but with double the frequency of an ordinary cosine graph. Also to amplitude is not from 1 to -1 but from 10 to -10.
  5. Caveman
    Apr 15, 2008
    471
    That's what I thought, but then I noticed that he defined V(t), but asked for i(t).
  6. mik3
    Feb 4, 2008
    4,846
    63
    If the voltage is applied on a resistor, the current (i(t)) will have the phase as the voltage but divided by the resistors value.
    If the voltage is applied to an inductor the current will lag the voltage waveform by 90 degrees, thus it will be a sine wave. Also divide by the reactance to find its amplitude.
    If the voltage is applied to a capacitor the current will lead the voltage by 90 degrees, thus it will be a sinewave. Also divide by the reactance to find its amplitude.
