PLZ FRIENDS HELP ME OUT
Discussion in 'Homework Help' started by muneeb21, Nov 15, 2008.
  1. muneeb21
    Nov 15, 2008
    HERE IS A NODE ANALYSIS QUESTION:
    IN COMPLEX NETWORK THERE ARE FIVE BRANCHES AND TWO VOLTAGE SOURCES.
    I FOUND V1 AND V2 BUT NOT CURRENTS IN EACH RESISTOR YET
    GIVEN THAT:
    R1 = 2 Ω
    R2 = 2 Ω
    R3 = 3 Ω
    R4 = 6 Ω
    R5 = 6 Ω
    E1 = 2 VOLTS
    E2 = 2 VOLTS
    I FOUND THE EQUATIONS BY NODE ANALYSIS
    EQUATION 1 IS (V1/R2)+(V1-E1/R1)+(V1-V2/R3)=0
    WHICH IS AFTER SOLVING BY PUTTING VALUES
    4V1-V2=3----------EQ:1
    EQUATION 2 IS (V2/R4)+(V2-V1/R3)+(V2+E2/R5)=0
    V1-2V2=1------------EQ:2
    AFTER SIMULTANEOUSLY SOLVING EQUATIONS
    V1=5/7 VOLTS
    V2=-1/7 VOLTS
    NOW I WANT TO FIND CURRENTS IN EACH RESISTOR SO PLZ HELP ME OUT
    BY FINDING CURRENTS IN ALL BRANCHES
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Is this a homework question? If so, let me know so I can move it into the homework section.
    Can you post a sketch of your circuit? It will insure that all of the members are clear on what it looks like.
    hgmjr
  3. muneeb21
    Nov 15, 2008
    no i dont have an sketch of this circuit!!!!!!!!!!!!
    yes its homework.
    please do something dear
    i m worry about that
  4. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Without the sketch, how does one know how the resistors and the voltage sources are connected?
