Pls Identify SMD component
Discussion in 'Electronics Resources' started by kavee, Dec 1, 2014.
  1. kavee
    Nov 26, 2014
    Can any one identify the smd component here? It looks like a transistor, which drives LED.
    By the way, this is on a treadmill controller board, where a series of such SMDs, together with associated 101 resistors are fried!
  2. kavee
    Nov 26, 2014
    Another photo (not good resolution though) on the component layout. W04 59 is the series of components marked as Q, and resistors are 101. Chip is a LS373 latch. together they drive a LED bar graph...
  3. Brevor
    Apr 9, 2011
    282
    56
    Yes, that is probably a transistor.
  4. Abhilash Sreekandan
    Dec 15, 2014
    It's a SOT (small outline transistor)
    Just go through the file smt nomenclature(google it)
  5. kavee
    Nov 26, 2014
    Thanks Abhilash. That's a SOT, but smt nomenclature doc does not reveal its identity. In other words, I do not think I can just replace it with another SOT randomly. I need the surface markings decoded or find an equivalent to replace.
  6. Abhilash Sreekandan
    Dec 15, 2014
    i don't know the exact part number, but you can check this part mpn- BC847B(mfr-NXP).
