Pls Help
extremeads1
Joined Feb 10, 2007
64
I'm interested in digital circuits but the problem for the academics the study is not detailed.
I would like to know which is the circuit used as control circuit in Single Slope Method Of ADC.
If possible post the internal circuitary of the same.
n9352527
Joined Oct 14, 2005
1,198
There is no single circuit for single slope ADC control. Different designers implement them differently. What you need to know is the control requirements and then just work out the circuit using the digital design principles that you've learned.
I have never seen any example circuit for the above posted on the net. Probably because it is not a common circuit that people use frequently.
