i have a 12volt electronic timer with 3digit led. connections: Coin slot, 12volts power, relay connect to TV to turn 'OFF' if no more time. coz i put a timer to my TV.
my problem is the Relay of a timer is 5pins, and i think this is not enough for my TV because every month i always change this relay. The time is zero but the TV still 'ON' then i change the 5pins relay then it's working good.
Please Help, if i change the relay to a bigger one with 8pins, 12volt will this work? if so what particular pins?
thanks
thanks
