pls help me !!
Discussion in 'Programmer's Corner' started by cheerzmiki, Aug 9, 2006.
  1. cheerzmiki
    Aug 9, 2006
    hi guys ,i am a newbie in asm language. I recently wrote a asm coding to run my 2 small dc motors through using PWM connected to my motor driver h bridge . But i had encountered some bugs when i run the program. The motor started to run before i press any button to start the motor and the buttons do not seems to respond well as at times they will only stop after a few presses , if not will keep running until i press the button again.I am trying it out on MPLAB ICD2. if some one know about this please let me know the reason. A million thanks .
    coding :
    list p=18f452
    #include p18f452.inc
    ;STARTUP CODE
    ; declare variables here
    sec equ 0x0000
    sec2 equ 0x0001
    Count2 equ 0x000
    Count1 equ 0x001
    STARTUP CODE
    org 00000h ; Reset Vector
    goto start
    PROG1 CODE
    ;program code starts here
    start
    ;***********initialisation*****************
    clrf PORTC ;initialise PORTC as output port and clear the port.
    movlw b'00000000'
    movwf TRISC
    setf TRISA ;init PORTA as input
    clrf PORTB ;initialise PORTB as input port.
    movlw b'11111111' ;initialise PORTB as input port.
    movwf TRISB ;initialise PORTB as input port.
    ;***********main body*************
    clrf T2CON
    bcf T2CON,TMR2ON
    setf PR2 ;PR2=oxFF
    movlw 0x7F
    movwf CCPR1L
    clrf CCP1CON
    bsf CCP1CON,CCP1M3
    bsf CCP1CON,CCP1M2
    bsf CCP1CON,CCP1M0 ;set CCP1 PWM mode
    movlw 0x7F
    movwf CCPR2L
    clrf CCP2CON
    bsf CCP2CON,CCP2M3
    bsf CCP2CON,CCP2M2
    bsf CCP2CON,CCP2M1
    bsf CCP2CON,CCP2M0 ;set CCP2 PWM mode
    checkSW
    btfsc PORTB,0 ;check for sw.it's normally low , high when pressed
    goto checkSW ;check for sw2 if sw is not pressed.
    bsf T2CON,TMR2ON
    movlw 0x7F
    movwf CCPR1L
    bsf PORTA,0 ;set forward direction
    movlw 0x7F
    movwf CCPR2L
    bsf PORTA,1 ;set forward direction
    call Delay
    wait4SW_release
    btfss PORTB,0 ;check if sw is still being pressed.
    goto wait4SW_release ;if sw is being pressed, check again
    bcf T2CON,TMR2ON
    call Delay
    goto checkSW
    ;*******************delay*******************
    Delay
    movlw 0xFF
    movwf Count1
    movwf Count2
    Repeat
    decfsz Count1,F
    goto Repeat
    movlw 0x01
    movwf Count1
    decfsz Count2,F
    goto Repeat
    return
    end
  2. BladeSabre
    Aug 11, 2005
    105
    If I understand right, your code acts on button-down, then continues on the next button-up. The unresponsive button would probably be improved by debouncing. I recently came across a good explanation and examples while working through the Pickit 2 User Guide and Lessons, found on Microchip's web site ( http://microchip.com/pickit2 ). That code would need to be converted to the 18F452 of course.
    EDIT: Sorry, I meant the Low Pin Count Demo Board's user guide (same page)...
