Pls help me explain this charger circuit
Discussion in 'The Projects Forum' started by TYYang, May 4, 2015.
  1. TYYang
    Apr 3, 2015
    18
    This is a solar energy charger and have a PNP 2N5401 transistor
    can anyone explain to me about how this circuit can work ? and the LED can light up when battery is implement.
  2. Ramussons
    May 3, 2013
    562
    92
    The "top" circuit has something wrong ....... What is source 1? Source 2? Single line sources? o_O
    Re trace the circuit.
    The "bottom" part seems OK.
    No 1.2 V NiMH battery1 , no Q1 base drive, no led1 drive.
    NiMH battery1 in position, yes Q1 base drive (battery charge current partly thru' R2, partly thru' Q1 base), led1 driven to light.
    and so for q2 q3 q4.
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    It wont work, the nimh batts wont charge.
  4. Ramussons
    May 3, 2013
    562
    92
    Yes, at 3 mA! o_O
    The OP wanted to know how an inserted battery lights the LED :D
  5. LDC3
    Apr 27, 2013
    920
    160
    How did you get 3 mA, I got less than 0.06mA.
    Are D1 to D4 diodes or zener diodes? If zener, what's the breakdown voltage? If they are regular diodes, why are they there?
