Pls help anybody knows the burnt resistor (R1) value of the Vcc of UC3844?
Discussion in 'General Electronics Chat' started by wkyong, Oct 27, 2009.
  1. wkyong
    Thread Starter Active Member
    Apr 29, 2008
    33
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Extrapolating from the example design in the datasheet (ST Microelectronics, Figure 11, page 8)
    For 117VAC in, they're using a 56k Ohm 2 Watt resistor to supply the circuit's needs. The rectified AC would measure around 163v.
    For 560v, you'd then need a 193.4k resistor rated at 7W.
    You could get close by using 110k and 82k 5W resistors in series.
