Pls check my first soldering project
Discussion in 'General Electronics Chat' started by gofar, Mar 31, 2015.
  1. gofar
    Mar 31, 2015
    7
    Hey all,
    I'm just starting in electronics. I've been practising soldering and desoldering before I attempted my first serious soldering. Image attached. Could you please give me feedback about the quality of the soldering?
    Is it OK or crap and I have to do it again?
  2. Treeman
    Member
    May 22, 2014
    158
    15
    Its lovely-I'm jealous.
  3. gofar
    Mar 31, 2015
    7
    Thanks.. you didn't see my hands shaking while soldering.... :)
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    The picture is not very clearly, but it still can see your soldering is quite good.
  5. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Excellent! I only wish industrial soldering was up to that quality!:):):)
    Sincerely
    HP
    JWHassler and gofar like this.
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    A bit too much solder or you aren't letting it flow enough (solder should look concave).. PWM1 needs to be reheated. Its too blobby :) CTS/RTS a bit too
    But not bad at all for a first timer.
    AD3 looks perfect from here
    Solder should fill 75% of the through hole
    gofar likes this.
  7. gofar
    Mar 31, 2015
    7
    Thanks, for the detailed feedback and commendations.
    I have to solder in one more header. So, I'll do a few more practice solders on a practice board with the aim of achieving concave solder joint before I do the extra soldering on this breakout board.
    It's certainly not easy and takes a fair bit of practice.
  8. OBW0549
    Mar 2, 2015
    1,395
    941
    Overall a good job. I've been soldering since I was 9 years old (I'm 65 now) and I do only slightly better than what you've shown in that photo. I agree with mcgyvr's comment about using somewhat more solder than is necessary, though.
    gofar likes this.
  9. pwdixon
    Member
    Oct 11, 2012
    488
    56
    I hope you are not soldering the pins while they are in the breadboard though as that might cause the breadboard connections to be damaged with the heat.
    gofar likes this.
  10. Treeman
    Member
    May 22, 2014
    158
    15
    is ad3 a bit cold?
  11. gofar
    Mar 31, 2015
    7
    Actually, I am. Thanks for letting me know of the potential problem with that method. Fortunately, this is one of several breadboards that I have so, I might just use that as my soldering breadboard just in case I damage it.
  12. gofar
    Mar 31, 2015
    7
    Well, it does look a bit anemic ...
  13. #12
    Nov 30, 2010
    16,704
    7,354
    No. Those fat looking legs are what you see after somebody has been all over a circuit board looking for an intermittent solder joint. It's never going to hurt anything except your wallet. You can use several extra pounds of solder per million circuit boards doing things that way.
    What? You aren't hand soldering millions of circuit boards?
    Then don't spend a moment worrying about the bulge of the droplet.
    Treeman, Hypatia's Protege and gofar like this.
  14. takao21203
    Apr 28, 2012
    3,578
    463
    Not just that also it gives a heatsink which increases possibility for well hidden cold joints.
    When I solder for instance SOIC, I always reheat it one or two times and look how the solder flows- because of bad experience.
    finally, look again with a magnifuying glass, remove the flux.
  15. MCU88
    Member
    Mar 12, 2015
    360
    35
    Soldering is an true art. My advice is...
    1. Heat joint with iron for 2 seconds (iron on an 45 degree angle touching both the pin and the donut on the board)
    2. Slowly feed in the solder to the pin and the pad (not the iron)
    3. Cease after adequate solder has flowed
    If it looks good then it IS good.
    gofar likes this.
  16. takao21203
    Apr 28, 2012
    3,578
    463
    I come accross pertially failed joints all the times or just on the margin, in consumer products, and looking at my own work.
    I solder for a long time and I'm not too bad at it, but have to check SMD work very carefully. It often needs another reheating.
    I'm not happy ith marginally SMD joints as they are very small.
