PLS and PLF in Mitshubishi
Discussion in 'General Electronics Chat' started by anhnha, Mar 12, 2015.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    Just curious, in Mitsubishi PLC there are 2 instructions below.
    PLS: leading edge output
    PLF: trailing edge output
    I just can't figure out what are the full forms of them.
    Any idea? :)
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Do you mean how they are typically implemented?
    They are typically used as a one shot leading/trailing edge trigger for a rung where an event may happen very briefly, do you need an example?
    Max.
  3. Dodgydave
    Jun 22, 2012
    5,142
    768
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Correction::mad: I was thinking of the LDP/LDF ;)
    Max.
  5. anhnha
    Apr 19, 2012
    776
    48
    Good evening!
    Actually, I wanted to know why Mitsubishi choose letter PLS and PLF as abbreviations for leading and trailing edges respectively.
    By the way, what is the difference between LDP and PLS?
  6. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    The LDP,LDF,ANP,ANF are all input instructions and register on a rising/falling edges.
    PLS uses a input to pulse operate on an output function, timer,counter etc.
    Why they chose those mnemonics is anyone's guess?
    The Mits manual shows and example of each.
    Max.
  7. anhnha
    Apr 19, 2012
    776
    48
    Thanks. By knowing the abbreviations I can remember them faster.
  8. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    There is always the manual derived description, e.g. PLS = PulseSe(t) PLF = PulseFalling, etc.
    Max.
  9. anhnha
    Apr 19, 2012
    776
    48
    Well, is it documented somewhere else?
    I thought PLS = Pulse Leading Edge(sound like S).
  10. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I am referring to the Mitsubishi Programming manual for FX PLC's.
    Max.
  11. anhnha
    Apr 19, 2012
    776
    48
    Could you attach it here? I can't find it online. Thanks.
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
