Plotting Pout-Pin graph in pspice?
Discussion in 'General Electronics Chat' started by eses23, Aug 11, 2015.
  1. eses23
    Aug 11, 2015
    I analyse cmos non-linear characteristic and I want to plot Pout-Pin graph. In DC sweep analysis I can sweep only voltage or current. I think I can sweep Pout by parametric sweep analysis.But I don't know how. I need help about that.
    Thanks in advance
  2. MikeML
    Oct 2, 2009
    Can you not plot an algebraic expression like V(R1)*I(R1) , which is the power dissipated in R1? You can in LTSpice.
    For example:
    A plot of NMOS Drain voltage and Power dissipation as a function of four decades of drain current.
    Note the expression required to get the power dissipation in M1. LTSpice builds that expression with just a Alt-Mouse click, but you could type it yourself...
    Note that LTSpice effortlessly knows how to do log plots...
  3. eses23
    Aug 11, 2015
    I am not sure about I understand you. I just want to plot Pout-Pin graph. I mean that I want to define as a Pin x-axis in plot window. I don't know much about LTspice. Isn't that possible plot the graph in pspice ? Do you have any notes about that ?
    jjw likes this.
