PLL Reference Signal
Discussion in 'Embedded Systems and Microcontrollers' started by bobo01, Apr 19, 2013.
  1. bobo01
    Apr 17, 2013
    5
    I am trying to understand the concept of a PLL. I understand that it essentially locks a VCO to a reference signal. I don't understand what this reference signal is and where it comes from? Why does the reference signal maintain the needed frequency?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. bobo01
    Apr 17, 2013
    5
    Short answer I found from there is:
    "A high stability oscillator like a crystal oscillator etc. are used."
    That is what I assumed, but then why use a PLL at all. Is it not better to use a crystal oscillator and a program counter?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    With a PLL you also have the posibility to multiply the frequency of the reference frequency.
    With an oscilator and a counter, you can only go down in frequency.
    Bertus
    absf likes this.
  5. bobo01
    Apr 17, 2013
    5
    So, that VCO, is esentially a frequency synthesizer? And it needs that reference crystal as the voltage may vary too much?
    Thanks.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The VCO is part of the synthesizer.
    Take a look at the attached PDF's.
    Bertus
    absf likes this.
  7. MrChips
    Oct 2, 2009
    12,648
    3,458
    My ARM mcu is clocked at a rock-stable 168MHz but it uses an 8MHz xtal.
    That is an example of what a PLL can do.
