PLL phase shifter
Discussion in 'The Projects Forum' started by ako, Jun 12, 2009.
  1. ako
    Mar 14, 2009
    10
    Hi All,Is it possbible to phase shift by 180% a 150-250kHz variable frequency PWM signal with a duty cycle of 40-60%using a single supply voltage LM565 PLL?Complete newbie badly needs help on this one. Thanks..
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Wouldn't it be easier to run the signal through an inverter? Or change the control? A 50% duty cycle remains 50%, 60% becomes 40%, and so on.
  3. ako
    Mar 14, 2009
    10
    I need the signal for interleaving purposes which is variable frequency, and a change in duty cycle wouldn't be right anymore.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Draw up a 60% duty cycle PWM signal on graph paper. Do a 180 deg. phase shift on it. See if that hasn't made it a 40% duty cycle signal.
  5. ako
    Mar 14, 2009
    10
    I think some kind of signal delay is what I'm looking for right now. Does phase shift always mean a change in duty cycle (assuming that D is not 50%)? Really confused about this topic.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A 180 deg phase shift simply inverts the signal. Signal delay is different. What kind of delay are you after?
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    You say 180%. Do you really mean 180 degrees?
    hgmjr
  8. ako
    Mar 14, 2009
    10
    180 degrees. Sorry.. The kind of delay that is implemented in interleaving PWM IC's in which the duty cycle is preserved. Only that in my case its variable frequency. Can a PLL do the job?
