PLL Frequency Multiplier
Discussion in 'Homework Help' started by nwo4life, Feb 23, 2007.
  1. nwo4life
    Feb 23, 2007
    I am using the LM565 PLL and a 74LS90 decade counter to design a times 5 frequency multiplier. I have figured out how to use the counter but I am having trouble with the LM565 PLL.
    My multiplier should work from (input range) 500Hz to 2kHz (ie. my outout range is therefore from 2.5kHz to 10kHz). I need help selecting the free running frequency (fo), hold in range (fH), and capture range (fc), and 3dB frequency of the lowpass filter (flpf). From the LM565 data sheet they give the following equations,
    fo = 0.3/(R1*C1) fH = +OR- 8*fo/(Vc) fc = +OR- sqrt(fH * flpf)
    Vc is the total supply voltage. If anyone can give me some hints and advice I would greatly appreciate it.
    THANKS
    Any hints would be appreciated.
  2. nwo4life
    Feb 23, 2007
    any help would be great.
