PLL frequency divide by 9.4
Discussion in 'General Electronics Chat' started by karthickkumar, Jun 28, 2009.
  1. karthickkumar
    Apr 13, 2008
    I have 94MHz pulses and i need to derive a Phase locked 10MHz clock from it. Please suggest a circuit for it and the ICs that can be used, as i am very new to electronics. Thanks in advance.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    With digital electronics you can only use integer divider numbers.
    You could divide the 94 Mhz by 47 to get 2 Mhz.
    This 2 Mhz can be mutiplied using a PLL to 10 Mhz using a divide by 5.
    Greetings,
    Bertus
  3. karthickkumar
    Apr 13, 2008
    HI, Thanks for your inputs. What ICs can i use ?. Are there ICs which can
    divide by 47 and are there ICs for PLL?. Please advice. I am very new to electronics and your input will help me learn.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    You have to do your research. There are a lot of CMOS/TTL that will do the high end, conventional CMOS can handle 10Mhz.
