plizz help me solve this problem... thnks
Discussion in 'Programmer's Corner' started by ramo, Feb 5, 2010.
  1. ramo
    Feb 5, 2010
    i need to interface a keypad 4x4 to xilinx spartan 3 starter kit board. the problem is that i need to use VHDL code so that the signal from the keypad will convert to ASCII code for the FPGA to read.
    example
    if i press button 1, the VHDL code will convert it to 0110001 (ASCII code for 1).
    help me. its my school project.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Keypads are usually implemented as pushbutton switches located in a row and column matrix. The location of any key on the keypad can be based on two coordinates: the row and column position for that key. Then you can use a look-up table​
  3. ramo
    Feb 5, 2010
    thnks for the reply. =)
