Please somebody help :( for my exam thanks
Discussion in 'Homework Help' started by Mark Rhenzo Medalla, Jul 19, 2016.
  1. Mark Rhenzo Medalla
    Jul 19, 2016
    Illustrate the following logical expression to its equivalent logical curcuit. 1.png
      File size:
      3.7 KB
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Welcome to AAC!
    1) Show us your best effort so far. This is a 'Homework help' forum; not a 'Homework done for you' one ;).
    2) What logical expression?
  3. Mark Rhenzo Medalla
    Jul 19, 2016
    please hellp
  4. Alec_t
    Sep 17, 2013
    5,973
    1,135
    So now we have 3 expressions.
    What have you been taught about logic gates and functions?
    Re-read item 1 of post #2.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    YOU need to show YOUR best attempt to work YOUR homework. We can then see where you are going wrong and try to get you back on course.
    Your expressions use four operators. What are they? Three are pretty standard for AND, IOR, and XOR. What's the fourth for?
  6. Ramussons
    May 3, 2013
    562
    92
    Take a look at De Morgan's laws.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In particular you need to tell us or provide a truth table for the operation indicated by the circle with a small dot inside in expression number 3. Whatever it is, it is non-standard, and we are not mind readers, so help us out here if you can.
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    It's looking increasingly like the TS doesn't know what it means, either. They just want someone to work their homework for them. Actually understanding what is being asked isn't needed for that.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Good point. A square box with the symbol inside works for me.
  10. shteii01
    Feb 19, 2010
    3,503
    512
    The sad part is that they don't even need to build the best circuit, meaning they don't need to do any simplification. They can simply make individual operation using specific gate, it will take a bunch of gates, but that just manual work, no brain work involved.
  11. RBR1317
    Nov 13, 2010
    265
    54
    The circumpunct symbol does indeed have a standard meaning, but is rarely used.
    https://en.wikipedia.org/wiki/Logic_gate
    absf likes this.
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You're right the circumpunct symbol is rarely used. It's right up there with the Sheffer Stroke, the Peirce Arrow, and the Quine Dagger which are a couple of obscure names for the more familiar NAND and NOR functions.
