My answers are very different from yours.Problem 1.
I came up with:
Ra=2558.7 Ohm
Rb=2450.5 Ohm
Yes, looks like mine are wrong. They work for 100 volt, but don't work for 80 volt.My answers are very different from yours.
The result works out slightly less than 100V.They work for 100 volt, but don't work for 80 volt.
Indeed they do.Hint: Ra and Rb happen to be round numbers.
Hi John,Only series- parallel / ohms law used. We dont have Thevenin Theorem yet.
How did you get the value of Ra and Rb..
I used the Voltage Division Theorem is it correct?
in Fig. 1 I use
Vout = Vin ( RL / RL + Ra )
100 V = 220 V ( 10k / 10k + Ra )
Ra = 12k ohms
for Fig. 2
Vout = Vin ( Rb / Rb + 12k )
Vout = 6.857k
is this is correct my answers? THANK YOU SO MUCH SIR/ Engr.
You need to show me how you use Thevenin, because I don't see how it can be use.I found Thevenin equivalents useful in obtaining the solution.
It would be interesting to see how others have correctly solved this. It's not a trivial exercise.
1.Two resistors A and B are connected in series across 220V DC source. When a voltmeter with a internal resistance of 10kΩ is connected across resistor A, the instrument reads 100V and when connected across resistor B, it reads 80V. Find Resistor A and B.
I think it's safe to go ahead and solve it.I found Thevenin equivalents useful in obtaining the solution.
Thanks.Your solution is almost correct except for a little k.
Nice work anyhow. I did it the long way.
As usual, there are a number of ways to go about it. Intentionally avoiding a "standard" technique, here is what comes to me off the top of my head.
We know that in the first measurement we have a reading of 100V and so we have a current through the meter of 100V/10kΩ or 10mA. The current resistor A is 100V/Ra while the current in resistor B is 120V/Rb. By KCL, we have
120V/Rb = 100V/Ra + 10mA
We know that in the second measurement we have a reading of 80V and so we have a current through the meter of 80V/10kΩ or 8mA. The current resistor A is 140V/Ra while the current in resistor B is 80V/Rb. By KCL, we have
140V/Ra = 80V/Rb + 8mA
Rearranging these equations we have
140V/Ra - 80V/Rb = 8mA
-100V/Ra + 120V/Rb = 10mA
Multiplying the top equation by 3 and the bottom equation by 2 and then adding the two equations together we get
(3*140V - 2*100V)/Ra = 24mA + 20mA
Ra = 220V/44mA = 5kΩ
Multiply top equation by 3, that gives you -240V/Rb in that equation.where the -80/Rb + 120/Rb>
