!!!please reply!!!
Discussion in 'Homework Help' started by NicolasChalhoub, May 29, 2013.
  1. NicolasChalhoub
    May 29, 2013
    7
    Can anyone forward me an asm code:
    that when i type on a keyboard, asteriks '*' on the LCD appear, if the password is correct, "OK" appear on the LCD, if its wrong, "WRONG PASS" appear.
  2. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    Please can you attach any attempts that you have made to write such code. I think you will find members will be more than willing to help if you show some willing to complete the exercise yourself. They won't unless they are feeling very generous be willing to provide you with complete code with no input on your part.
  3. NicolasChalhoub
    May 29, 2013
    7
    Can u attach me the proteus file (if u can)
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Please understand why you do not deserve to be helped:
    1) Your subject title is of no use to anyone.
    2) Your request is vague with very little information.
    3) You have not shown your own work.
    4) You cannot learn how to program in a hurry.
  5. NicolasChalhoub
    May 29, 2013
    7
    I attached the asm file. can u help me now? :)
  6. t06afre
    May 11, 2009
    5,939
    1,222
    You should post your schematic also. And tell us why and how you struggle. What have you done to debug this?
    As some others have mentioned. We can nor will we just serve a turn key ready solution. But we will not mind giving you hints and help. If you show some effort
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    Okay, I replied. This is all your thread title indicates that you want.
  8. Eric007
    Aug 5, 2011
    1,054
    33
    lolol...:D
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    Don't you think it is just a bit unreasonable to expect others to wade through nearly 700 lines of assembly code for some processor in some assembly language, neither of which you bother to even mention, in order to find some bug that you don't bother to describe?
    On top of that, you want strangers to open a file named DANGERRRRR and nearly all the comments are in French when you are posting on an English-language forum. I'm guessing the sections with comments in English are code fragments you boosted from someone else.
    Draw a flow chart of what you want to have happen and map it to your code. In the process of doing that, there is a good chance you will find your problem.
    mkbutan and Eric007 like this.
  10. Eric007
    Aug 5, 2011
    1,054
    33
    Your problem description is very poor and everybody can tell that you just need a canned solution without putting any effort! Too bad Son!
    All I can say from a quick scroll is that you speak french...lol... (je parle aussi francais) and I like your macros for bank selections it makes it easier...instead of trying to figure out what is the current bank and which bit(s) should be set or cleared!
    And You did not even mention which PIC you are using and bah bah bah you don't sound really serious about it!
    Come on get to work!
