I am a student of Electrical Engineering and I am currently working on a biomedical device which stimulates a human arm through functional electrical stimulation technique. Now for instance, if something gets damaged in the circuit due to which a large amount of current starts flowing then, the human arm can get damaged. So, I want to make something like a breaker myself which will break the circuit right then.
I considered using a fuse but the problem with a fuse is that it will allow the current flow through to arm atleast once before cutting off the connection.
I want to make a limiting circuit that has a low foot print so that the device doesn't look too large. Could you please give me some suggestions?
Any help will be appreciated.
Thank you!
Thank you!
