Please.. need help to connect a negative voltage end to transistor
chrisakuragi
Joined Mar 3, 2011
16
Sir, I need to switch a power supply using transistor from negative end.. with respect to common ground..
the output of the power supply is negative voltage with respect to common ground.
Please help me to connect using a transistor...
Schematic diagram would certainly help!
