Please I need help with 74160 decade counter
Discussion in 'Homework Help' started by spidermanIIII, Jun 15, 2014.
  1. spidermanIIII
    Nov 22, 2013
    76
    first thank you for trying to help me, I am new in studding electronics the problem is I tried to read the data sheet but there are some things I can't understand P0 to P3 are Parallel Inputs what is the meaning of parallel input in decade counter and how can I use them secondly what is CEP and CET and what are they use for and what is TC
  2. shteii01
    Feb 19, 2010
    3,504
    512
    From datasheet:
    CEP - count-enable P
    CET - count-enable T
    They both need to be set to High (2-5 volts) to start the count.
    The inputs ABCD is to load the starting value. I guess if you connect them to ground (Low), then you load a starting value of 0000. If I read datasheet right, the '160 is BCD counter. So the counter goes:
    0000
    0001
    0010
    1001
    You start at 0, you end at 9.
  3. spidermanIIII
    Nov 22, 2013
    76
    thank you sir but I wanna know what will happen if i connect CET and CEP once active low and once active high what will happen
  4. shteii01
    Feb 19, 2010
    3,504
    512
    Nothing.
    The count starts when they are both High. If they are both Low, the count is off. If one is High, the other is Low, the count is off.
  5. shteii01
    Feb 19, 2010
    3,504
    512
    If you look at the logic diagram of '160, you will see that CEP and CET are connected to AND gate. Do you know truth table for an AND gate?
    The output of an AND gate is High only when inputs are High.
    So when you send CEP Low and CET High, the output of the AND gate is Low. When you send CEP High and CET Low, the output of the AND gate is Low.
    spidermanIIII likes this.
  6. spidermanIIII
    Nov 22, 2013
    76
    sir I see the logic diagram and I fond CEP and CET are conected to NAND gate but the output where it is going to in the attached image
  7. shteii01
    Feb 19, 2010
    3,504
    512
    I was looking at this one: http://www.ti.com/lit/ds/symlink/sn74160.pdf
  8. spidermanIIII
    Nov 22, 2013
    76
    sir can you help me to understand what highlighted
  9. spidermanIIII
    Nov 22, 2013
    76
    this is what i highlighted
  10. shteii01
    Feb 19, 2010
    3,504
    512
    The count is paused.
    All the cases are listed in the Mode Select Table.
  11. spidermanIIII
    Nov 22, 2013
    76
