Please help!!!
Discussion in 'The Projects Forum' started by tjleitch, Jul 19, 2014.
  1. tjleitch
    Jul 19, 2014
    i need some help with a radio control receiver. I'm working with a dual FM receiver and want to find a small remote to work with it. is there anything that i can use to work with this receiver. Its a futaba FP-R127DF dual conversion FM 7 channel receiver.
    I burnt up my radio that work with it but want to fin some smaller to remote that i could use to transmit a signal to a servo.
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    The simplest solution would be to find another transmitter meant for that receiver. Unless you have quite a lot of experience in such things, don't even think about building one.
    Perhaps if you post the spec of the original equipment, someone here might know of possible replacements.
    Have you seen this?
  3. tjleitch
    Jul 19, 2014
    what can be used for this a receiver, I want to use a remote small for it but remote about the size of a key remote if possible. Transmitter is a 72MHZ, 50MHz band
    Modulation - FM
    Receiver is 72MHZ, 50MHz
    Intermediate frequency-1st IF 10.7MHZ, 2nd IF 455khz
