Please Help
alex22j
Joined May 3, 2014
5
1. Using a 5v sin voltage supply as input, a resistor and necessary number of diodes, design the diode limiter circuits for the following specifications:
a) limit the output voltage within the range [0, V1], where V1 is a number of your choice from the set [3.0, 3.5, 4.0]
b) limit the output voltage within the range [-V1, V1].
2. Simulate the designed circuits and correct the design if necessary (might need several steps).
3. Analyze the results, compare theoretical with the experimental, draw conclusions.
4. Hint. The Von of the actual diodes you will use may depend on the selected Q-point. Thus the value of the resistor should be selected appropriately to provide for the desired value of the current. You may need to find it by experimenting with the circuit.
This is what I need to design, but I have no idea how to make the simulation circuit! The circuit I built, doesn't limit my output voltage to V1, what do I do?
Please help!
Thank you
DerStrom8
Joined Feb 20, 2011
2,390
Please show us your work on this so far. We will not give you the answers, but we can help you fix any errors in your own design.
Regards,
Matt
alex22j
Joined May 3, 2014
5
I don't know if this image of my circuit works or not.
But I have a 5V sin voltage in series with a 100K resistor. V1(3V) is in series with Diode 1 and that is in parallel with Diode 2.
#12
Joined Nov 30, 2010
18,224
So do I.
I don't know if you're allowed to use the DC voltage source, but you're supposed to know.
alex22j
Joined May 3, 2014
5
According to the instructions, I have to use the 5V sine voltage as well as a DC source of V1. When I simulate the transient analysis, the I cannot seem to get the output to limit from 0 to 3V max. 3V is my DC V1.e
