Yes this is correct.No, the circuit is broken, the power supply stops supplying current to the circuit and the only remaining current in the circuit is that which is stored in the capacitor.
Is there now any voltage across R1 or any current through it?
No difference.P.S. does it makes a difference weather the switch is on the positive side of the power supply or the negative? (in my task it is between the power source and R1) .
I placed it where I put it because of the mix up naming R1 and R2.
Ok we are getting there.Oh, and I have to find the current function through the resistor R2 !
So at t=0 the voltage across R1 is zero, the voltage across R2 is the voltage across AB with A more positive than B. This is equal to 130 volts.
We can now say that all the current from the capacitor passes through R2 only (This would not be true for a different circuit so be careful in your reasoning). Thus the capacitor discharge current = the current in R2 at all times t>0
I have drawn the direction of my I2 arrow consistent with this discharge current flowing from positive to negative from the capacitor through R2. this direction is called conventional current.
At this point you will need to help me because I do not know what you have been taught about the equations for the discharge of a capacitor through a resistor so tell us about this and we can continue to crack the problem.
Thus we can
